Setting application-specific data for the ISC had failed. In such a case, CM's MLAG mode functionality will not function properly.
This is a rare condition which may be related to software, and may require a reboot of the switch to correct the problem. If it persists, contact technical support and provide outputs of 'show switch', 'show log'.
Error
Unable to set application-specific data for ISC %isc%, Error = %err%
| Name | Type |
| isc | uInt16 |
| err | sInt |
